CUBE with SIP REFER
Aubin Gouthon
Hello Guys,
I'm trying to make SIP REFER work on CUBE but no luck. What am I missing?
When CUBE receives the REFER message, it sends "SIP/2.0 400 Bad Request"
The goal is to get the CUBE to send an INVITE to the address in the REFER-TO header.
I do have the following commands on the inbound dial-peer:
-no supplementary-service sip refer
-refer consume
This is the REFER message received:
REFER sip:5167@10.154.25.50:5060 SIP/2.0
Via: SIP/2.0/UDP 10.140.175.244;rport;branch=z9hG4bKr2cKN3g0FS8Xp
Max-Forwards: 70
To: "Softnet." <sip:5167@10.154.25.50>;tag=C0AB0034-1EEA
Call-ID: 6E76D4A3-C85B11EA-8838EA6E-8E8920FA@10.154.25.50
CSeq: 22994694 REFER
Contact: <sip:1418@10.140.175.244:5060;transport=udp>
User-Agent: FreeSWITCH-mod_sofia/1.8.6~64bit
Allow: INVITE, ACK, BYE, CANCEL, OPTIONS, MESSAGE, INFO, UPDATE, REGISTER, REFER, NOTIFY, PUBLISH, SUBSCRIBE
Supported: timer, path, replaces
Refer-To: <3711346@10.154.25.50>
Referred-By: <sip:10.140.175.244>
Content-Length: 0
X-Route: ad_reset
And CUBE responds with this:
To: "Softnet" <sip:5167@10.154.25.50>;tag=C0AB0034-1EEA
Date: Sat, 18 Jul 2020 18:29:32 GMT
Server: Cisco-SIPGateway/IOS-15.4.3.M3
Content-Length: 0
Contact: <sip:5167@10.154.25.50:5060>
10 Replies 10
Jonathan Schulenberg
If memory serves, REFER handling is off by default. You need to enable it with supplementary-service sip refer.
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/voice/cube_sip/configuration/15-mt/cube-sip-15-mt-book/voi-cub-sip-dyn-refer-handling.html
Hi Jonathan,
I have the command:
no supplementary-service sip refer in dial-peer configuration mode.
This is for the REFER consumption, an INVITE should be sent towards the
Refer-to dial peer.
Ah right. Assuming that you already verified the call legs are matching the dial-peers you expect them to, does CUBE have an outbound dial-peer match for the Refer-to header?
Yes I have an outbound Dial-peer for the destination URI
Could this be due to the Referred-By header Referred-By:
10.140.175.244> ?
Is CUBE expecting an URI in this format : user@IP ?
10.140.175.244>
By default CUBE will only consume the user/LHS of that URI and route it like any other numeric destination. The outbound dial-peer would need to be destination-pattern 3711346
If you really want to route the full URI you'll need to turn on requri-passing.
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/voice/cube/configuration/cube-book/sip-supp-uri-based-dialing.html
Jul 21 00:37:32.173: //16624339/5BCD33800192/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:1418@10.140.175.244:5060 SIP/2.0
Via: SIP/2.0/UDP 10.154.25.50:5060;branch=z9hG4bKC4B19824D0
To: 1418>
Date: Tue, 21 Jul 2020 00:37:32 GMT
Call-ID: 32B539DA-CA2111EA-8521EA6E-8E8920FA@10.154.25.50
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE: 1800
Cisco-Guid: 1540174720-0000065536-0026409451-1696176906
User-Agent: Cisco-SIPGateway/IOS-15.4.3.M3
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1595291852
Contact: 5167>
Expires: 180
Allow-Events: telephone-event
Max-Forwards: 68
P-Asserted-Identity: "Aubin Gouthon" 5167>
Privacy: none
Session-Expires: 1800
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 245
v=0
o=CiscoSystemsSIP-GW-UserAgent 66 2427 IN IP4 10.154.25.50
s=SIP Call
c=IN IP4 10.154.25.50
t=0 0
m=audio 19074 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
Timestamp: 3678136652173
UTC Timestamp:3678136652173
Received:
SIP/2.0 100 Trying
To: 1418>
CSeq: 101 INVITE
Timestamp: 1595291852 0.000088
Content-Length: 0
Received:
SIP/2.0 100 Trying
To: 1418>
CSeq: 101 INVITE
Content-Length: 0
Jul 21 00:37:32.177: //16624339/5BCD33800192/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
To: 1418>;tag=XQSmFScUDBg5j
CSeq: 101 INVITE
Contact: 1418>
Accept: application/sdp
Require: timer
Allow-Events: talk, hold, conference, presence, as-feature-event, dialog, line-seize, call-info, sla, include-session-descrip tion, presence.winfo, message-summary, refer
Session-Expires: 1800;refresher=uac
Content-Length: 251
P-Asserted-Identity: "1418" 1418>
v=0
o=FreeSWITCH 1595269176 1595269177 IN IP4 10.140.175.244
s=FreeSWITCH
c=IN IP4 10.140.175.244
t=0 0
m=audio 22676 RTP/AVP 0 101
a=fmtp:101 0-16
a=silenceSupp:off - - - -
a=ptime:20
Timestamp: 3678136652177
UTC Timestamp:3678136652177
Jul 21 00:37:32.181: //16624339/5BCD33800192/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:1418@10.140.175.244:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 10.154.25.50:5060;branch=z9hG4bKC4B19916A3
Max-Forwards: 70
CSeq: 101 ACK
Privacy: none
Content-Length: 0
Timestamp: 3678136652181
UTC Timestamp:3678136652181
Jul 21 00:37:34.677: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.140.175.244;rport;branch=z9hG4bKQU5c5BpySa4Qg
Max-Forwards: 70
To: "Aubin Gouthon" 5167>;tag=CC488E8C-1FA8
CSeq: 23092135 REFER
Contact: 1418>
Refer-To: <3711346@10.10.140.150.101>
Referred-By: 10.140.175.244>
Content-Length: 0
X-Route: ad_reset
Timestamp: 3678136654677
UTC Timestamp:3678136654677
Sent:
Date: Tue, 21 Jul 2020 00:37:34 GMT
Content-Length: 0
Contact: 5167>
Jul 21 00:37:44.082: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:5167@10.154.25.50:5060 SIP/2.0
Via: SIP/2.0/UDP 10.140.175.244;rport;branch=z9hG4bKr4y56661pKtac
Max-Forwards: 70
CSeq: 23092136 BYE
Reason: SIP;cause=600;text="BLIND_TRANSFER"
Content-Length: 0
Timestamp: 3678136664082
UTC Timestamp:3678136664082
Sent:
SIP/2.0 200 OK
Date: Tue, 21 Jul 2020 00:37:44 GMT
CSeq: 23092136 BYE
Reason: Q.850;cause=16
P-RTP-Stat: PS=588,OS=94080,PR=125,OR=20000,PL=0,JI=0,LA=0,DU=11
Content-Length: 0
UTC Timestamp:36781366640825167>1418>5167>1418>5167>5167>1418>10.140.175.244>1418>5167>1418>1418>5167>1418>1418>1418>5167>1418>5167>1418>5167>5167>5167>1418>5167>
I have a dial-peer for 3711346, I'm not trying to use URI dialing. Here it is:
dial-peer voice 72 voip
 description #REFER-INVITE#
 session protocol sipv2
 session target ipv4:10.140.150.101
 voice-class sip early-offer forced
 dtmf-relay rtp-nte
 codec g711ulaw
 fax protocol none
 no vad
I attached the full SIP dialog. It looks like CUBE is rejecting the SIP REFER it received.
Only things I noticed are: FROM and TO headers are switched, and the Cseq is huge.
Yeah, I noticed the Request URI, FROM, To, and Cseq but I don’t spend enough time staring at REFERs to say that’s wrong.
What caught my eye however is the Refer-to header from your trace: the IPv4 address in the RHS is illegal. Is that legit what the trace contained or were you trying to mask/obscure some of the IPs?
Not sure what happened, probably when I was cleaning the file and removing other calls from the trace.
I just took a fresh new logs, it is attached.
When I bypass the CUBE and use a direct SIP trunk from CUCM, the SIP REFER works.
1 thing missing when using CUCM, it doesn't pass the custom header: X-Route: ad_reset
I'm looking into SIP Normalization script to copy the header from the SIP REFER and add it to the INVITE. Any idea how to make this work?
I appreciate all your help on this. Thank you
hello, may I know how you solve the issue?
