No outgoing Sip-ua CME
Kevin100
Hai
Outgoing calls not work with ITSP, sip-ua show registred
here is debus ccsip messages
Oct 24 09:17:43.370: //336/13490923812F/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:65139333@XXXXXX:5060 SIP/2.0
Via: SIP/2.0/UDP 62.150.254.82:5060;branch=z9hG4bK1F62174
To: <sip:XXXXXX@XXXXXXX>
Date: Sun, 24 Oct 2021 09:17:43 gmt
Call-ID: 140CF547-33E211EC-8134927C-FC4CAC7A@62.150.254.82
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE: 1800
Cisco-Guid: 0323553571-0870453740-2167378556-4232883322
User-Agent: Cisco-SIPGateway/IOS-15.7.3.M8
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1635067063
Contact: <sip:XXXXXX@XXXXXXX:5060>
Call-Info: <sip:62.150.254.82:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
Expires: 180
Allow-Events: kpml, telephone-event
Session-ID: 499fd8f0ecce55af9020b5047f6b5be6;remote=00000000000000000000000000000000
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 442
v=0
o=CiscoSystemsSIP-GW-UserAgent 7377 7839 IN IP4 XXXXXXXX
s=SIP Call
c=IN IP4 XXXXXXXX
t=0 0
m=audio 16468 RTP/AVP 0 8 18 116 101 121
c=IN IP4 62.150.254.82
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=yes
a=rtpmap:116 iLBC/8000
a=fmtp:116 mode=20
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=rtpmap:121 frf-dialed-digit/8000
a=fmtp:121 0-15
a=ptime:20
a=maxptime:20
Oct 24 09:17:43.378: //336/13490923812F/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 500 Server Internal Error
Via: SIP/2.0/UDP XXXXXXXXX:5060;received=XXXXXXXX;rport=5060;branch=z9hG4bK1F62174
To: <sip:65139333@XXXXXXXX>;tag=1c1607669765
CSeq: 101 INVITE
Reason: SIP ;cause=500 ;text="Classification Failure"
Content-Length: 0
Oct 24 09:17:43.382: //336/13490923812F/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:65139333@XXXXXXXX:5060 SIP/2.0
Via: SIP/2.0/UDP XXXXXXX:5060;branch=z9hG4bK1F62174
To: <sip:65139333@XXXXXXXXXX>;tag=1c1607669765
Max-Forwards: 70
CSeq: 101 ACK
Session-ID: 499fd8f0ecce55af9020b5047f6b5be6;remote=1a44c5ad214e502a99feb1261f25cedd
Content-Length: 0
Incoming working fine, all were good many months until last week
thank you
If this has been working fine previously and then stopped out of the blue there must have been a change made on either the ITSP side or in the IOS configuration. Not very likely that a working thing would fail for no reason.
Response Signature
