CUC caller input send call to subscriber [not available]
chinpohpang851
I configured a call handler with 2 layers of greetings which work fine but i need the caller input 1 to send caller to subscriber ext1234 i got message [ext 123 is not available, record msg at the tone.]
I need it to work like when caller input key 1 and transfer call to ext 1234. pls help
#NOTE: Ext1234 is working fine in CUCM and currently signed in to IP Phone.
On the active Greeting, on the caller input option, did you select "Transfer to Alternate Contact Number"?
Please let me know
Carlo
Please rate all helpful posts "The more you help the more you learn"
Please follow this document.
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/9x/administration/guide/9xcucsagx/9xcucsag060.html#pgfId-1056109
Below are the steps.
Call Handler--> Edit--> Caller Input--> Click 1--> Call Action--> Select Transfer to alternate contact number then provide the extension
Make sure to check the Ignore Additional Input
Balram
Please rate if you find this helpful
Thank You
Balram
My CU is older version (7) so there's no such option. Anyway, I use another call handler to transfer to ext. Thanks
