05-03-2023 01:16 PM
I've had a strange issue come up the last couple weeks with a couple agents in our environment. Both users are utilizing an 8865-model phone (video phone). Both have an RDP associated to them that of course routes to their cell phone (SNR).
What I found is that our system is not sending a call to user's cell phone (when associated to an extension) when that caller has a video-based phone. I'm assuming that the video request fails, and instead of re-trying without video, it just fails completely and will not call the user at all. Has anyone ever heard of this before?
Solved! Go to Solution.
05-03-2023 01:25 PM
05-03-2023 01:25 PM
Possibly you’ll need to use this command. Video Suppression
05-03-2023 01:28 PM
I would assume that we would then we would no longer be able to have video calls. And the two users in questions want to be able to utilize them internally with each other.
05-03-2023 09:38 PM
Calls internally would not I assume pass through the gateway, right? As the command is put either on a dial peer or globally in the router that facilitates PSTN services it would not affect internal calls.
05-04-2023 02:48 AM
In the CUCM SIP trunk configuration try to check "Retry Video Call as Audio"
Also as Roger mentions before use the below command in the CUBE global voice configuration
#voice service voip
#sip
#audio forced
