CUCM 11.5 hardware support
waqas sardar
Dear Team,
CUCM version 11.5 is support hardware c220-M3SBE ?
Please advise with document .
Jitender Bhandari
Hi Waqas,
The server itself is EOL
http://www.cisco.com/c/en/us/products/collateral/servers-unified-computing/ucs-c-series-rack-servers/eos-eol-notice-c51-737442.html
For CUCm 11.5 UCS supported hardware ESXi versions check the link below
http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/uc_system/virtualization/virtualization-cisco-unified-communications-manager.html
http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/uc_system/virtualization/collaboration-virtualization-hardware.html
(Rate if it helps)
JB
We already have c220-M3SBE with cucm 10.5. we are planning to upgrade to version 11.5.
Is there any hardware issue ?
Hi Waqas,
check the readme for 11.5 OVA, if your server can support the requirement listed in OVA you should be good
http://www.cisco.com/web/software/283088407/133457/CUCM_11.5_VirtualServerTemplate8_v1.1_Readme.pdf
(Rate if it helps)
JB
As long as any UCS server shows up in VMWare HCL list and carries a supported CPU model you can use it for UC deployment (CM in this case). Refer below:
http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/uc_system/virtualization/collaboration-virtualization-hardware.html#servercompatibility
Deepak
