08-10-2023 07:17 AM - edited 08-10-2023 07:17 AM
CUCM 12.5 The installation has enountered a serious internal error
Any suggestions on what I can do?
08-10-2023 08:09 AM
That seems to be a bit of a vague message.
- Is that a Pub or Sub?
- At what point during the install did you get that error?
- Did you run the space cleaning cop file?
- How much max storage does your vdisk drive have?
- Is this an upgrade or fresh install?
That's just a few of many possible questions you'll need to provide answers too before I can maybe assist. Hopefully someone else can chime in at some point.
08-10-2023 12:09 PM
Adding to @KennethButler24475‘s list:
- Was the VM deployed from the Cisco-provided OVA?
- Is the host running a supported version of VMware ESXi for that version?
- If upgrading, were any settings changes required to the VM? Check the release notes and upgrade guide.
- Does the underpinning compute and storage hardware meet all specs-based requirements? For example, a supported Intel CPU model, not AMD.
