03-20-2017 02:07 AM - edited 03-17-2019 09:51 AM
Can someone suggest me a good 3rd party call reporting tool for CUCM 11.x which provides standard incoming and outgoing calls reports and also has user restriction to view the calls for a set of extensions by department-wise. I was searching for quite some time now but didn't find a software that meets the requirement. Any help on this is highly appreciated. Thanks in advance.
Best Regards,
Ajin Skariah.
Solved! Go to Solution.
03-20-2017 02:26 AM
Here you can explore..
http://docwiki.cisco.com/wiki/CUCM_FAQ
Apogee http://www.sdtinc.com - Call Accounting, work order, trouble ticket, billing, business intelligence. In-house or SaaS.
Suresh
03-20-2017 02:26 AM
Suresh
03-23-2017 01:03 AM
Thanks Suresh...
03-05-2019 05:18 AM
Thanks Suresh for the List.
