01-29-2014 11:36 PM - edited 03-16-2019 09:30 PM
Is there any utility available to export CUCM 4.1 configration in Excel as we do in cucm version 7.x, 8.x and 9.x with bulk export utility.
Saurabh
01-30-2014 12:11 AM
You should get the DMA 4.1 tool on Cisco website.
Look at the following Thread.
https://communities.cisco.com/thread/10412?start=0&tstart=0
01-30-2014 04:15 AM
Hi Saurabh,
You can BAT version 5.1(4) which is compatible with CUCM 4.1.x. Details of the export utility are explained in the link below
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/bat/5_1_4/bat_exp.html
Also, if you use DMA it can only be used during the install of a linux based cucm version when it asks for the dma file during the initial stages of installation, the DMA tar file cannot be used anywhere else.
Manish
