Hello Community, I use the Report Web Tool from CUCM 8.x (not CAR/CDR) and search for a description what the some Report Fields output means.For Example: Field: Count:Media Termination Point 2etc...
Hello All,CallManager: 8.0.3I was wondering if anyone knew of a report I could run, or something along those lines, that could give me usage or frequency of which a DID number has been called..? We're going over some of our local numbers from TelCo a...
Hi All, I need to upgrade from 6.1.2 to 10.X and was wondering what would be the best strategy. I'm thinking of the following :-replicate existing 6.1.2 cluster on UCs servers using OVA V7 template.Upgrade to 6.1.4 or 6.1.5load the cop fileuse PCB to...
Hello. I am wondering if anybody can assist with a problem I am having. I have a client with a UC560, using a SIP trunk. Calls are able to make it to the UC from the outside, and are answered by the Auto attendant. When you dial a persons extension a...
Hi,I have to registered a X-lite softphone with CME. Xlite is able to make outbound calls but no incoming calls. A Cause Value=57 (Bearer capaility not prensebtly available) error + Forbidden (SIP) message is received.Any idea?Below the setup:voice ...
Hi Voice Community,I recently configured my Voice Gateway (ISR 2921) for ccm-manager MGCP fallback. I was able to register the gateway and the T1 with my call manager (CUCM 9.1). I also have SRST configured and pointed to the gateway's address as th...
Hi all,I started implementing CME systems a few years ago at our customers headquarter. Now, as he opened a lot of new branches i decided to make an offer for the new BE6000-Bundle.Is there a migration process to upgrade the CME licenses to the new U...
Hello,I have CUCM 8.6 and I want to make incoming calls restriction for some numbers, those nr. are from another Country ( not registered in CallManager ), is this posbile?Thanks
The SRND states:"Cisco Unified CM 9.x currently does not support the ASA Phone Proxy and TLS Proxy features."Does anyone know if this is going to be supported in the future, if not what is the alternative solution?Thanks in advanceStewart
Hi experts!I am struggling with securing a CME that has (and needs to have) a public facing IP without any ACLs. The problem is that external SIP clients seem to be able to dial in and right back out again. I was hoping my translation-profile would s...
Hello friends, i need a free software ip phone that i can register in my cisco 3945 CME. Do you have any suggestions? ThanksPS. i need SCCP protocol ip phone
Hi,As per http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/requirements/guide/cme90spc.html, 2921 can support 100 SCCP phones in CME mode. Are the same numbers applicable even if we run IPSec VPN on 2921?Experts, please share your views.Thank...
We currently run CUCM 6.1 for our voip solution. We have multiple sites connected which all use H323 voice gateways running on Cisco 2821's.We've recently setup an H323 voice gateway in a new regional office. It is using a Cisco 2821 with a PVDM32 in...
OK, curiosity question:The various SM-SRE modules, when installed with Cisco Unity Express, are supposed to have a default number of ports available. For example, the ISM-SRE-300-K9 module is supposed to have two ports on it by default when installe...
Cisco has informed me that the 7937 is no longer orderable as of this week in CCW. The original end of sale date was 31/3/14 but they have stopped accepting orders early. The replacement is the CP8831-K9 but you have to be careful to make sure the ve...
Subject | Author | Posted |
04-02-2025 08:56 AM | ||
03-31-2025 08:42 AM | ||
03-27-2025 12:55 PM | ||
03-27-2025 10:13 AM | ||
03-26-2025 12:17 PM |
User | Count |
3 | |
2 | |
2 | |
1 | |
1 |
