**ERROR**: CCPMSG_InCall: ChannelID IE invalid 100(0x64) in SIP voice gateway
dadahit3000
Hi all,
I am configuring a SIP voice gateway. After finsihing the config, the outbound calls are working properly. But I met some issue for inbound calls.
There is no debug log for show ccsip message and show voice dialpeer command. Only q931 has the debug log.
Can any one have any idea for this issue?
below is the debug shows for show isdn q931.
   Jun  1 05:27:49.435: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8  callref = 0x03A3
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xE1858384
Preferred, Interface 5, Channel 4
Calling Party Number i = 0x2181, '18600586101'
Plan:ISDN, Type:National
Called Party Number i = 0xC1, '82197910'
Plan:ISDN, Type:Subscriber(local)
High Layer Compat i = 0x9181
Jun  1 05:27:49.439: ISDN Se0/0/0:15 Q931: Received SETUP  callref = 0x83A3 callID = 0x0004 switch = primary-net5 interface = User
d8w-sr-2811f20a-vpn#
Jun  1 05:27:49.439: ISDN Se0/0/0:15 **ERROR**: CCPMSG_InCall: ChannelID IE invalid 100(0x64) rejecting call
Jun  1 05:27:49.443: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x83A3
Cause i = 0x80E418 - Invalid information element contents
下午01:28:17: Zhuliang: Jun  1 05:27:49.439: ISDN Se0/0/0:15 **ERROR**: CCPMSG_InCall: ChannelID IE invalid 100(0x64) rejecting call
acampbell
**ERROR**.CCPMSG - searching CCO seems always to show that these are IOS software bugs.
Firstly upgrade the router to the latest IOS from Cisco that will fit your DRAM & FLASH.
Retest
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
Any update.
paolo bevilacqua
To what are you connecting? Call comes with explicit interface indicator IE, that is not normal for ISDN E1.
Hi ,
did you find solution for this.
i am facing the same issue with E1.
000108: Jan 21 21:27:21.233: ISDN Se0/1/0:15 Q931: Received SETUP  callref = 0x82FE callID = 0x0002 switch = primary-ni interface = User
000109: Jan 21 21:27:21.233: ISDN Se0/1/0:15 **ERROR**: CCPMSG_InCall: ChannelID IE invalid 100(0x64) rejecting call
000110: Jan 21 21:27:21.233: ISDN Se0/1/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x82FE
Shalid K.C
