CUCM 6.X file download using file get command
haouaswajih
Level 3
Level 3
Dear Networkers,
I would like to download the MOH file in the CUCM. The file name contains space character. I am using the following command to list MOH files.
file list activelog mohprep/*
The file name that I would like to download contains space characters. I can't download it, i am facing the error :
Missing file-spec or invalid command option specified.
Valid options: [reltime|abstime][match]
Is there a way how I can download this file please ? tried to put the name in between " " and ' ', but this didn't help.
Can you please advice ??
Thanks in advance.
Chris Deren
Take a DRS backup of the system and you'll have access to the files.  This is doable in versions until 8.X where the DRS file is encrypted.
HTH,
Chris
Anyone got any new ideas for downloading a file with space in it for post 8.X ?
Wildcard does not work, tried some quotes but no go. I don't think it should allow you to upload a file with space if it has such problems dealing with them.
Try escape character '\' before the space, if that doesn't work you'll have to go to TAC for deleting it via root access.
8.6.2 does give you an error if the file name has spaces.
-Atul
Ayodeji Okanlawon
Maybe you shoudl try and download using the wildcard..
file get activelog mohprep/*.ulaw.wav
file get activelog mohprep/*.alaw.wav
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
