CUCM 7.1.3 error : Unable to delete phones
chirag pinara
The setup includes two servers in cluster : Publisher & Subscriber (CUCM 7.1.3).
All the services are running. Replication is good.
I am unable to delete IP phones in CUCM. Its showing ther error : "One or more record did not get deleted. User defined routine(Licenserequest) execution failed".
The CM has consumed extra 3 units than that has been authorized. There are many phones that are configured but are unregistered. Unable to delete them too.
I have restarted both the servers. Still of no avail.
Any kind of help would be highly appreciated
Thankyou....
Gordon Ross
Level 9
Level 9
If replication is good across the cluster ("utils dbreplication runtimestate" on the console, or RTMT are your friends) then I think you're going to need to call Cisco TAC.
GTG
Please rate all helpful posts.
Dhaval Sheth
Is there any other error while you login via console/webpage ????
Are those servers hard booted or shutdowned im properly ?????
Please try to restrt the licencing service of all the call managers.
Try to delete/add phone while licensing service is off .
If this doesn't work you have to go with the TAC ....
good luck
Thanks Gordon & Dhaval.
I had raise a TAC. After checking the logs I had to run the "System recovery cd". But of no avail. So had to rebuild the server.
