Hello,I have a Bogen TPU100B paging system that requieres a contact closure to trigger the night ringer.I have a 2921 gateway and EM and FXO card. Is there a way I can make a contact closure with those interface?Thanks
Greetings!I have just bought an ATA 187 device and need to configure it for a fax line in my business with my CUCUM 7.1.5.30000-1 install. However, I don't have the ATA 187 device listed as an option when adding a new device... only the older ATA 186...
Hi, I want to listen or participate to a analog conversation on VG248 port with a share line on the supervisor phone model 7962.I have UCM 7.1.5. Anybody have a idea how I can configure the VG and phone to do this?Thanks,
Hi all!I have the new cisco ip phone 303 sip with asterisk pbx.How to install the ringtones? What i can set in the xml configuration file?On the other hand, how to configure another language for the spa303? Where can i find the spanish dictionary for...
Hi, thanks in advance for any help you guys can give me.We have a overhead paging system connected to our voice router on an fxo port. Some times, users would accidentally call the paging line. Is there a command I can use to see who is connected t...
We are upgrading to a Cisco IPT solution. In the meantime we will be using legacy (i.e. non-POE) switches. In this case the spec for the 7937 Conference station requires for the use of a power brick (CP-PWR-CUBE-3) which I assume is to to provide the...
I have got 7942G and want to register it on Asterisk server. What phone load version do I need to get it work?Regards
Hi all,I have a problem about CUCM.admin:show environment temperatures ID Temp Type Threshold1 33C Threshold 70C2 17C Threshold 39C3 255C Threshold 127C...
Hi, kindly i have a Cisco CME v7, i have install and configure E1 Card, and it was working ok. BUT, there is a problem that the operator can recieved only one call on this e1, also when try to dial on the e1 number from the outside you will recieved ...
Hi guys, My customer is using CCM4.2 with 3 servers running clustering. I need to know how to handle the following situations.1. In case Primary server dies. Can I promote the secondary to ack as a primary server? How to do that?2. In case Sec...
Hi Mates,I have a doubt with my call manager version 5.1.3I need to configure the time for phones in Tel Aviv and within Date/Time Group Information I can choose these 2 time zones.Jerusalem Standard Time - (GMT +02:00) IsraelJerusalem Standard/Dayli...
HelloWe have been having this problem since we had our Cisco phone system installed and I've yet to find a solution.We have a meeting room with a 7941 phone in them, this phone is not used extensively however after say a week you will go to use the p...
Hello everyone,I have UC 520, I have five numbers from PSTN , three belongs to Company A and Other belongs to Comapnay B. When some one dial out from inside to outside through PSTN line it just pick any of the random line, I need to configure such ...
I have tried to set up a CUCM 7.1 hunt pilot to provide a single number for our support team. The line group consists of extensions that are also configured for Unified Mobility (single number reach) with a top down distribution. This works well as ...
I’m running CUCM 7.15 and I’m trying to find a way to setup a button on the phone that when pressed will forward to a previously designated number. I guess the “CFwdAll” + cell number is too hard for some people. That was a joke, but for users that...
Subject | Author | Posted |
05-08-2025 04:33 AM | ||
05-05-2025 11:16 AM | ||
04-30-2025 05:24 AM | ||
04-30-2025 01:54 AM | ||
04-29-2025 03:01 PM |
User | Count |
5 | |
3 | |
1 | |
1 | |
1 |
