09-10-2011 07:45 AM - edited 03-16-2019 06:55 AM
Hi All,
I'm configuring CUCM 7.1 for the first time after working with 4.x and have a question. The option for the NANP does not show up in the drop down list in the device pool config. Do I have to install it? Should the option be there by default?
Thanks.
Solved! Go to Solution.
09-10-2011 09:27 AM
You get the chance to select it when you actually type an @ in a route pattern or translation pattern. Before that it is greyed out, as you aren't using a dial plan with that partition/trans pattern.
Aaron
Please rate helpful posts..
09-10-2011 09:03 AM
I don't recall being able to assign a numbering plan to a device pool. I did a quick check on the 4.1 admin guide and I am still in the dark. Based on the rest of your question I assume that you may be using "@" patterns and route filters?
You can select NANP when configuring a route pattern. There is a drop down list to select numbering plan. NANP is loaded by default. Others can be downloaded from CCO.
HTH.
Bill
09-10-2011 09:21 AM
Hi Bill,
You're right and I'm glad yoou understood what I meant. The problem I have is that drop down list is greyed out i.e. there is nothing to select. I read that it was loaded by default but I would have thought that I'd have at least the option to select the NANP.
Is there something I need to enable or should I just accept that it is there and move on?
Thanks for your info.
Charles.
09-10-2011 09:27 AM
Aaron
09-10-2011 10:07 AM
Aaron is correct (+5 A.), you need to put the wildcard character ("@") in the pattern field to enable the drop down.
-Bill
09-10-2011 10:16 AM
Thanks for your help gents. I can rest easy knowing that it is as it should be.
