CUCM 7: Dial out to PSTN gives busy
csshenoy80
Level 2
Level 2
I am configuring H323 GW with CUCM7. Have the required gateway configuration with dial-peer pots:
dial-peer voice 100 pots
destination-patter 9T
direct-inward-dial
Port 0/1/0:15
Also have the Route pattern configured for international 9.00!.
The isdn q931 gives the below message:
*May 31 11:47:09.336: ISDN Se0/1/0:15 Q931: Applying typeplan for sw-type 0x12 i
s 0x0 0x0, Calling num 0XXXXXXXXXXX
*May 31 11:47:09.340: ISDN Se0/1/0:15 Q931: Applying typeplan for sw-type 0x12 i
s 0x0 0x0, Called num 00YYYYYYYYYYYYY
*May 31 11:47:09.340: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8 callref = 0x0136
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Calling Party Number i = 0x0081, '0xxxxxxxxxx'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '00yyyyyyyyyyyyy'
*May 31 11:47:09.524: ISDN Se0/1/0:15 Q931: RX <- SETUP_ACK pd = 8 callref = 0x
8136
Progress Ind i = 0x8288 - In-band info or appropriate now available
*May 31 11:47:09.552: ISDN Se0/1/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0
x0136
Cause i = 0x80AC - Requested circuit/channel not available
*May 31 11:47:09.700: ISDN Se0/1/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x81
36
*May 31 11:47:09.704: ISDN Se0/1/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref =
0x0136
Kindly suggest.
22 Replies 22
paolo bevilacqua
Router disconnects, that is not normal.
Which exact IOS is this ?
Cisco IOS Software, 3800 Software (C3845-ADVENTERPRISEK9-M), Version 12.4(11)XJ4
, RELEASE SOFTWARE (fc2)
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
That should not happen. Perhaps is related o something on the h.323 side, check with "debug ccapi all".
the debug ccapi all is not supported on the cisco router. Any other config / debug which need to be checked.
It should be supported, or some variation of debug ccapi.
it has "debug voip ccapi", also, I am able to dial out local numbers, only international numbers are giving me busy tone.
The international numbers get dialed out using the "csim start" command.
I have checked the route patterns and they seem to be fine.
Please suggest.
Exactly what is telco expecting for these values:
leading 00s?
no 00s but international?
00s + unknown?
00s + national?
If u don't know call your telco, many expect a combination of parameters to allow the calls
java
if this helps, please rate
java
BT is the telco. As well, I have configured the DID.
The telco is sending 6 digits on the gateway. On CUCM H323 Gateway, I have configured the significant digits as 4, with CSS which has access to the IP Phone partitions, but when i dial the DID number form PSTN, I get the announcement, number not in use. As well, from q931 debug, i get the message , unallocated number.
Please suggest.
Un allocated number is usually a CSS/partiton problem
two things
1. Check the CSS on your gateway that it has the partition of the Phones in it.
2. Post the output of your debug voip ccapi inout here..
If you are using h.323, you need to check your dial-peer config. You can post that here too and I can have a look
Please rate all useful posts
The css on gw has the access to ip phone partiton.
attached is the ccapi debug for DID incoming call, in which the call failed.
I tried with translation pattern as well with all 6 digits coming form the service provider, it didn't help either.
Please suggest.
Ok..So here is your problem...
dest=222088
cisco-desttype=0
cisco-destplan=1
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
cisco-redirectreason=-1 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
*May 31 17:53:44.091: //-1/D136EACF803C/CCAPI/cc_api_call_setup_ind_common:
Interface=0x68742DF8, Call Info(
Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Scree
ned, Presentation=Allowed),
Called Number=222088(TON=Unknown, NPI=ISDN),
Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFl
ag=TRUE,
Incoming Dial-peer=3, Progress Indication=NULL(0), Calling IE Present=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALS
E), Call Id=-1
*May 31 17:53:44.091: //-1/D136EACF803C/CCAPI/ccCheckClipClir:
In: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Present
ation=Allowed)
*May 31 17:53:44.095: //-1/D136EACF803C/CCAPI/ccCheckClipClir
May 31 17:53:44.099: //136/D136EACF803C/CCAPI/ccCallDisconnect:
Cause Value=1, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Ca
use=0)
from the debug..the number called is 222088...The debug shows that there is no dial-peer for this pattern.
You need to have two call legs. In the debug we can only see the incoming dial-peer, we did not see the outgoing dial-peer which the gateway will use to route the call to callmanager.
What is the extension of the phone you are trying to reach? is it 222088?
Can you post your sh run here?
please find the sh run below:
Building configuration...
Current configuration : 2692 bytes
version 12.4
hostname TESTRTR
boot-start-marker
boot-end-marker
card type e1 0 3
enable password ***********
no aaa new-model
network-clock-participate wic 3
ip cef
isdn switch-type primary-net5
voice-card 0
codec complexity high
dspfarm
dsp services dspfarm
voice call disc-pi-off
voice service voip
h323
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
voice class h323 1
h225 timeout tcp establish 3
call start fast
voice translation-rule 1
rule 1 /222080/ /8001/
rule 2 /222081/ /8002/
rule 3 /222082/ /8003/
rule 4 /222083/ /8004/
rule 5 /^\(222\)\(...\)/ /2\2/
voice translation-profile PSTN
translate called 1
username TEST
username TEST1 secret 5 **************************!
controller E1 0/3/0
framing NO-CRC4
pri-group timeslots 1-8,16
vlan internal allocation policy ascending
interface GigabitEthernet0/0
ip address X.X.X.X 255.255.255.0
duplex auto
speed auto
media-type rj45
no keepalive
standby 0 ip Y.Y.Y.Y
h323-gateway voip interface
h323-gateway voip bind srcaddr X.X.X.X
interface GigabitEthernet0/1
ip address X.X.X.X X.X.X.X
duplex auto
speed auto
media-type rj45
no keepalive
interface FastEthernet0/0/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/3/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn bchan-number-order ascending
no cdp enable
ip http server
no ip http secure-server
control-plane
voice-port 0/3/0:15
dial-peer voice 1 voip
preference 1
destination-pattern 8...
voice-class codec 1
session target ipv4:X.X.X.X
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 2 voip
preference 2
voice-class codec 1
no vad
dial-peer voice 3 pots
translation-profile incoming PSTN
destination-pattern 9T
incoming called-number .
direct-inward-dial
port 0/3/0:15
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
password ********
login
scheduler allocate 20000 1000
end
Ok,
Your translation rule does not have the pattern for the dialled number.
The dialled number is 222088.
So you need a rule for 222088
you mean rule to convert 222088 to 2088? I already have the voice translation to convert 222088 to 2088. kindly suggest.
