CUCM 8.0 to CUCM 8.0 SIP trunk MOH issue
p.blavier
Hi all,
I have got a very simple lab with 2 publishers configured with a SIP trunk (no cube), so we have  :
PhoneA->CUCM1->SIP->CUCM2->PhoneB
The trunk is just working fine, I can dial in both directions, however when a phone places a remote phone on hold I can't get MOH (unicast) working
All devices (trunk, MOH servers and phones) are in the same region and the same location, this to have things as simple as possible. Local MOH is working. So only G711 is used.
Does anyone have an idea ? I'm getting lost
Ayodeji Okanlawon
I asked you to do that because sometimes during call hold etc, there is a break in media path. This sometimes causes issues, hence why I asked for you to use MTP because with that there is no break since the call will be terminated on MTP.
Then only thing left now will be to look at both cucm logs and ipvms logs to see whats going on.
Sent from Cisco Technical Support Android App
Please rate all useful posts
10 Replies 10
p.blavier
I m now wondering if thats supported cause the audio source should be defined by the holding device ( the trunk or the mtp in my case i dont know) and the moh server is defined by the holdee device (it is properly configured in my case)
I m getting lost :)
p.blavier
Does that mean we cant have moh when sip trunk are used, i dont believe it
Check that ICT has an MOH server configured in a MRGL either in the device itself or DP
"opportunity is a haughty goddess who waste no time with those who are unprepared"
p.blavier
I do have a mrgl applied to the trunk
for test purposes, check mtp required and then ensure you have mtp on the mrgl...for the trunk...test again and let us know the result
I have tried to add an MTP on the trunk already, did not makek any difference
also I dont know why an MTP should be involved here ?
Hi Philippe.
Which protocol are IP  Phones using?
Let us know.
Carlo
Please rate all helpful posts "The more you help the more you learn"
Sccp for phones on both sides of the trunk
Ayodeji Okanlawon
you right, MTP can makes sense, if the call breaks in media path during "on hold"
The thing that confuses me is we cant tell the SIP trunk which Audio Source to use, and as the audio source is "linked" to the holding device (which could be the trunk) it doesnt work :/
Maybe this setup can only work with a CUBE router ?
