ā11-24-2015 09:17 PM - edited ā03-17-2019 05:00 AM
Hi All,
I have phones registered on CUCM 8.5 with a registered h323 gateway connected via T1 and WAN ethernet to a CME gateway at remote site.
incoming calls from BR phones to CUCM 8.5 registered phones HQ phones rings and connects,
however outgoing calls from CUCM 8.5 HQ phones rings the BR phone at the CME remote but when I connect the BR phone the HQ phone continues to ring although the BR phone at the CME remote gateway shows connected?
HQ phones <------> CUCM 8.5 <-----> h323 gateway (IP to IP configured) <---------> CME gateway <----------> BR phones
ive attached the following;
h323 gateway config
CME gateway config
debug cch323 session
debug voip ipipgw
Solved! Go to Solution.
ā11-24-2015 10:00 PM
To resolve this issue, perform these steps:
More details here
https://supportforums.cisco.com/document/13376/ip-ip-h323-ios-gateway-calls-between-two-remotely-located-cisco-callmanagers-fail-one
Manish
- Do rate helpful posts -
More details here
Manish
ā11-24-2015 11:08 PM
Manish, is this not for two cucm clusters? The issue here is between cucm and come..
ā11-24-2015 11:34 PM
This settings is not specific to ICT, it can be causing the issue in this scenario as well. A quick test can be done to check, else the traces can be looked at to confirm if this is indeed the issue.
Manish
ā11-24-2015 11:11 PM
Can you please send the following
1.debug voip ccapi inout
2. Debug h225 asn1
3.debug h245 asn1
Include the calling and called numbers
ā11-29-2015 10:37 PM
Thankyou Manish, this has resolved my issue. Apologies for the delayed reply.
ā11-29-2015 11:20 PM
No problem, thanks for updating the post.
Manish
