CUCM 8.5 - SCCP45.9-2-3S
Ayaz Khan
Hello All,
We upgraded all our phones to SCCP45.9-2-3S from SCCP45.9-1-1SR2, and now notice that call history doesn not show.  When we press directory button and try to veiw placed calls, missed calls, recived calls, we see no entries.
I don't see any error messages displayed on the phone.
If anyone has encountered this issue or has any ideas please let me know.
8 Replies 8
Ayaz Khan
Issue is being noticed on 7945 and 7911 phones.
Ayaz
I am also facing same issue with 7941 IPT phones. Someone please help
Try to upgrade latest release firmware version (SCCP)
For 7945:cmterm-7945_7965-sccp.9-3-1SR1-1.cop.sgn
For 7941:cmterm-7941_7961-sccp.9-3-1SR1-1.cop.sgn
For 7911:cmterm-7911_7906-sccp.9-3-1SR1-1.cop.sgn
Thanks VNK. Can you please guide a bit on how to do it ?
Furthermore when i search the file you mentioned for 7941 on google below link says its for CUCM 4x but i need info regarding CUCM 8.5:
http://tinyurl.com/ayfstj7
Follow below Steps:
s 1: goto Cisco Unified OS Administration in CUCM
s 2: goto software upgrade-->install/upgrades
s 3: add new and browse path of your downloaded firmware file
s 4: upload it.
After Finish above steps.
s 5: Goto CUCM Admin page
s 6: Device --->Device Setting-->Device Defaults (goto particular ip phone model & copy phone load name). then Click Update.
s 7: goto the phone--> particular phone (as you need to upgrade the firmware version)-->device page--> change phone load name.
s 8: update it.
s9: restart TFTP Service in Cisco Unified Serviceability.
Thanks VNK but like i stated earlier the file you mentioned (cmterm-7941_7961-sccp.9-3-1SR1-1.cop.sgn
) for my 7941 IPT is only compatible with CUCM 4.x as mentioned in the link i gave above.
Please check again because we have CUCM 8.5
No, VNK is completely right, you need to review what the downloads say.
.EXE were used in Windows releases (4.X)
.COP is what we use in CUCM release 5.X+
That is explained in the link that you posted
He already provided you with all the info you need.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Raulpompa
It is very likely that you need to remove and load the ITL file on each phone, Follow below Steps:
in the phone press settings -> Security -> Trust List -> Select ITL File and press **# -> more options -> Erase
The ip phone restarted and you can able to view placed calls, missed calls, received calls
Raul PZ
