CUCM 8.6.2 configs
lambay2000
Level 2
Level 2
Dears,
It might be very silly nd stupid  for asking this question but it has been asked to me.
  1. How i can pull the configs of complete CUCM ------------Is it the backup of CUCM will help??? and in which application we can open the backup files
  2. How i can pull the configs from CUCM for only MGCP Gateway.
  3. Statistic for CUCM and voice gateway ---- I think RTMT tool will help
thanks pls answer
2 Accepted Solutions
Chris Deren
1. you cannot open the configs taken via DRS backup as those are encrypted, your native option would be to use export BAT features. Alternatively you can use 3rd party such as Uplinx
2. See above
3. RTMT it is
What he means is you generally use DRS to take cluster backups. These backups are not something you can open or view, you can just backup and restore whole servers or the cluster.
If you want to export config, you can use 'export/import' in BAT (bulk administration) to export the config as CSV formatted files. These can be opened and manipulated.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
5 Replies 5
Chris Deren
2. See above
3. RTMT it is
Dear Chris
Thanks for replying
your native option would be to use export BAT features, ???? I didnt understood
.thanks
Aaron
Dear chris and Aaron Harrison,
Thank experts for replying i will try to execute as suggested and update the rating.
thanks
+5 to you both
I was able to export successfully.
