CUCM 8.6 and Unity Live Call Recording
David.Pellat
All,
I need to setup a solution whereby when a user is on an external call that they need to record, they can press a button on the phone that will direct the traffic to a unity server to silently record the voice stream.
Is this solution possible?
If so is there any good configuration guides or examples?
David
ronpatel
Level 8
Level 8
HI
See if below link helps you.
http://www.ciscounitytools.com/Documents/Unity/LiveRecord/Help/LiveRecordAppNote.htm
regards
Ronak Patel
rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
The Version of Unity is Unity Connection  8.6.2
i will have a look for some relevant documentation. I assume the process would be the same?
Yes for Unity 8.x is same procedure.
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/8x/administration/guide/8xcusag140.html#wp1057024
regards
Ronak patel
Rate helpful posts.
