CUCM 8.6 data migrate
zhengxh1987
Hi,guys!
     I need to split my cluster into 2 clusters.The old cluster has more than 20,000 phones,after spliting,the new cluster will handle 2,000 phones.
     So I need to migrate the phone data in the next few days.What would consider the most Convenient way to migrate the phone data?
     Version of 2 clusters are both 8.6.2.
     cheers!
Jaime Valencia
Since they're the same version use BAT , either the export/import option or the phones with all details option.
If they're the same version, it's just a matter of getting the files from one to the other to do the import.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Jaime Valencia
java
java
