08-15-2012 02:26 AM - edited 03-16-2019 12:43 PM
Hi,guys!
I need to split my cluster into 2 clusters.The old cluster has more than 20,000 phones,after spliting,the new cluster will handle 2,000 phones.
So I need to migrate the phone data in the next few days.What would consider the most Convenient way to migrate the phone data?
Version of 2 clusters are both 8.6.2.
cheers!
Solved! Go to Solution.
08-15-2012 06:38 AM
Since they're the same version use BAT , either the export/import option or the phones with all details option.
If they're the same version, it's just a matter of getting the files from one to the other to do the import.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
08-15-2012 06:38 AM
java
