IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5820 Views
  • 14 replies
                   Hi Everyone,We are in the process of implementing VOIP in the building for around 1350 staff by using the current IT network (Cat7a),My questions are:- The best and highest codec and protocol to get the best voice quality- the expe...
moh123321 by Level 1
  • 389 Views
  • 3 replies
I need to verify something becasue I am getting multi different answersI have a CUCM cluster, customer has a multi forest domain. All users that I will need are in a single domain. If that is the case do I need AD/LDS?Mike
miket by Level 5
  • 311 Views
  • 1 replies
Resolved! E1 PRI
Hello,I have a E1 link and i want to distribute as follows:6 channels for contact center------what commands i have to configure on voice gateway any sample configuration please.How can i assign 6 No's DN to these 6 channels so that these channels sho...
adamgibs7 by Level 6
  • 1109 Views
  • 21 replies
Hello,I have configured the extension mobility and my CUCM is integrated with AD, authentication is also done by AD everything working perfect. what is the PIN for the user when he wants to login,, and also how can i set a PIN for 500 users.My networ...
Hiwhen i am installing uccx 7 in windows 2003 the following error is showing computer hardware provided by cisco systems ,inc is required to install cisco unified contact center express installation will now abort
Hello,I am using a translation pattern to forward incoming fax calls from PRI1 to PRI2. The scenario is as below:PRI1>>>H323>>>CUCM>>>H323>>>PRI2>>>FAXIf I send a fax directly to PRI2, the fax is successfuly received without any errors.But if I send ...
