08-28-2014 07:44 AM - edited 03-16-2019 11:56 PM
What gateways are support in this call manager rls? I am needing to know if the 3640 and 3745 routers are supported. Thanks
Solved! Go to Solution.
08-28-2014 07:58 AM
Both models are still present on gateway list on CUCM 9.1 version
Carlo
08-28-2014 07:48 AM
Hi.
Both models are pretty old :) anyway they can be added as H323 gateway to CUCM which still supports that signaling protocol.
Carlo
08-28-2014 07:50 AM
How about as a MGCP gateway?
08-28-2014 07:58 AM
Carlo
08-28-2014 08:04 AM
Thank you very much.
08-28-2014 11:55 AM
Plus 5
