12-12-2013 08:12 AM - edited 03-16-2019 08:50 PM
Hi all,
I have just tried to add the device for 8831 and I didnt see that option available? Can someone guide be to getting the device packages for this version. I went on the software download site and it didnt have any device packages for that version of call manager.
Please advise what are my next steps?
12-12-2013 08:21 AM
Next step - upgrade to 9.1.2
12-12-2013 08:36 AM
You are hitting a bug here. You need to upgrade to the latest device pack.
Rate if it helps
Ajay
12-12-2013 08:44 AM
Hello mnsh,prasad,
So for the upgrade to the 9.1.2, what is recommended? 9.1(2) or 9.1(2)SU1?
Hello ajay,
There are no device packs for my release. What device pack were you talking about?
12-12-2013 08:45 AM
Hi ,
it is supported on CUCM 7.1(5), 8.5(1) ,8.6(2) ,9.0 and above.
No devpack is required for this CUCM version but I think u need to upgrade the CUCM to 9.1(2) as suggested by Prasad.
what is firmware version u are using for 8831?
9.3(3) SIP loads and support files for 8831 Conference IP Phone (Part 4)
regds,
aman
12-12-2013 08:49 AM
you can upgrade CUCM to latest version 9.1(2) SU1
regds,
aman
12-12-2013 09:00 AM
Thanks much. very grateful for the quick response everyone.
12-12-2013 09:07 AM
Hi ,
thanks for the ratings.Share the outcome after u upgrade.
[+5] to Prasad and Ajay .
regds,
aman
12-13-2013 01:57 PM
Hi All,
I was able to upgrade the cluster successfully. The device package for the 8831 is available but when the phone was added i got the error registration rejected. Any ideas?
Also for my unity connection cluster should i also upgrade to the same version on call manager?
12-13-2013 08:48 PM
Did you restarted the cluster after installing device pack ?
12-13-2013 11:55 PM
Can u share the show version active from Call Manager?Is auto-registration enabled on call manager?
Look for any unassigned DNs and if exist, delete them.
If still unsuccessful,please try adding phone manually .
regds,
aman
12-14-2013 05:36 AM
Hi All,
I was able to get the phone registered. I am still confused why it worked though. I will have to check another 8831 to see if the same issue occurs.
I did try both auto reg and manual but same issue. What resolved the issue is disabling the dhcp setting on the phone. the phone got a dhcp address but i decided to enter it manually but as soon as i disabled the dhcp server it registered immediately.
Any ideas on this, i am going to check the dhcp server to see if there is anything strange.
12-14-2013 06:19 AM
Hi Guys,
So it turned out to be a firewall issue. An any-any rule was invoked for testing and it seem that the firewall was blocking the dhcp release setting to the voice network.
Thanks much.
Also the question on the cisco unity connection, should I also upgrade to match the version of call manager that was upgraded yesterday? I dont know if there is a cisco best practice.
12-14-2013 10:41 AM
you can refer the matrix.What is the UCXN version u are using ?
Supported Version Combinations for Cisco Unity Connection 2.x and Later with Cisco Unified Communications Manager
2.x and Later
9.1(2), 9.1(1), 9.0(1),8.6(2),8.6(1),8.5(1),8.0(x), 7.1(x), 7.0(x), 6.1(x), 6.0(x), 5.1(x), 5.0(x), 4.3(x), 4.2(x), 4.1(3)
you can upgrade if your H/W permits and u have UCSS/ESW contract .Also, if looking for any new features on UCXN 9
regds,
aman
