04-04-2014 06:45 AM - edited 03-16-2019 10:22 PM
Hi Everyone,
Previous to version 9.1.2 we could disassociate a directory number from a device but still call forward it to voicemail or another number. I have version 9.1.2 and this is not possible anymore.
Instead i get the “Your number could not be dialled, please consult your directory…” – previously on CM6, we could have DN’s which went to VM but weren’t associated with devices.
I susspect we have to now use Translation patterns instead but was just wondering if this is a fault or something that has been removed
Many thanks in advance
Amre
Solved! Go to Solution.
04-04-2014 07:09 AM
Well, you definitely have to assign a DN to a device before you can forward it.
I would advise them to use Translation Patterns, but if they resist that or do not know how to use them, just show them how to create a fake device. I used fake devices so that I could more easily search in directory numbers to find the dummy extension. It was more convenient for me to do it that way. Experiences may vary...
04-04-2014 06:57 AM
8.6 works this way as well. You can create a fake device and apply the forwarding there, if you are trying to avoid Translation Patterns. Just make it a fake mac address. However, the best way to do it is Translation Patterns.
This is not a fault or error in the system. I think it is an "encouragement" to use Translation Patterns.
04-04-2014 07:06 AM
Thanks Jonathan
I don't mind Cisco's "Encouragement" its the customer's that don't like change :)
So are we def saying that this does not work as before and best to use translation patterns?
04-04-2014 07:09 AM
10-29-2015 05:11 AM
Checking the "actice" box in the DN config makes this work.
10-29-2015 05:11 AM
04-04-2014 08:05 AM
I think this should still work. You just need to have the "Active" checkbox checked on the directory number.
