05-26-2015 08:11 AM - edited 03-17-2019 03:08 AM
Is there a way to findout the total number of calls made in CUCM. Need to know internal and outbound/inbound calls made in the system. I don't really need to know cdr, but totals.
AK
05-26-2015 08:16 AM
You can use SQL commands at the CLI to pull 90 days worth of calls. The script will depend on the version of CUCM you are running.
05-26-2015 08:26 AM
Thanks for the response.
Brandon - do you know what the command will be for CUCM version 9.x ?
I will research this further.
05-26-2015 08:41 AM
http://www.ucguerrilla.com/2012/03/cucm-sql-queries-installment-5.html
Example:
run sql car SELECT * FROM tbl_billing_data
05-26-2015 08:22 AM
Hi Ayaz,
The best way is to process CDR to get the total calls made on a range of date. Another solution is to use RTMT going to Performance-> Csico H323/SIP/FXO -> Call Completed but it 's inaccurate information.
