CUCM and VG224
Have a customer that has a bunch of VG224's in their current CUCM 10.5 environment.
Looking to upgrade them in the short term to 14.0 and I am hoping that becides the fact that they are EOL that they will still work.  so that in the next budget we can get them replaced with new VG310's.
Any hopeful comments as to if there will be problems?
thanks
They work in CM 14.
Response Signature
Rajan
Hi Richard,
It will work but please be aware of the following note from cisco:
//If you register an End of Life phone to Cisco Unified Communications Manager, you will get limited support:
  • No bug and security fixes will be provided for that phone.
  • We will not provide fixes for Cisco Unified Communications Manager in regard to these phones unless the same problem can be replicated with supported phone models.
  • The older phone models may be a security risk in your network. Cisco will not evaluate whether an end of life phone model will be affected by a security vulnerability.//
Rajan
Please mark all useful posts as helpful and solutions as accepted wherever applicable
