CUCM ( BE6000 ) - Outbound call issues , no impact on dialing extensions .
support
We have found strange outbound dialing issues , no impact or response on dialing  extension after receiving AA messages .
Solved by changing MTP setting on both CUCM and gateway router ( for PRI ) . Steps are shown below .
COnfiguring MTP in CUCM
1.Configure Voice Card
    router(config)# voice card 0
                    dspfarm
                    dsp services dspfarm
                    codec complexity flex
2.SCCP configuration.
    router(config)# sccp local <lan interface of cucm>
                    sccp ccm <ip address of cucm for which the mtp should be registered> identifier 1 version <version of cucm using>
                    sccp
3. DSPFARM profile creation.
    router(config)# dspfarm profile 1 mtp
                    maximum sessions <number of sessions provided>
                    associate application SCCP
                    codec g711ulaw
                    no shutdown
4.SCCP group configuration.
    router(config)# sccp ccm group 1
                    bind interface <lan interface of cucm>
                    associate ccm 1 priority 1
                    associate profile 1 register MTP_<IOS Router hostname>
Configuration on BE6000
1. Login to CUCM.
2. GoTo Cisco Unfird Serviceability.
3. Activate MTP Services.(this will automatically create an MTP profile)
4. GoTo Cisco Unifed Communication.
5. Tick the checkbox "Enable Media Termination Point" in Cisco trunk configuration.
Claudion.com
Chris Deren
The question should be why you needed to check it, and unfortunately your description does not allow us to answer it for you.  Please let us know what PSTN trunk type you are using, i.e. SIP, PRI, POTS, etc, what is the protocol between the voice gateway and CUCM i.e. SIP, H323, MGCP to get started as needing MTP on every call is not a good solution.
