Bookmark
Subscribe
691
CUCM Bulk Admin question
techguy
Level 4
Level 4
hi,
IS it possible to change any parameter lets say CSS or Route Partition or enable/ disable any feature for all the range of specific extension.
For example if i want to change the CSS of extension 1200 to 1250, will have to do it one by one ? Thanks
CUCM Version:
System version: 7.1.5.34080-1
You can use the same process.. phones>add/update lines
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Ayodeji Okanlawon
You can use the bulk admin interface to do this. Go to CCMadmin>Bulk admin (tab)> phones>update phones>query
then search for the phones using their extensions... scroll and tick CSS box (select the CSS you want), then click on run job immediately
Thanks for your half answer
What if i want to change line settings of the phone? I mean to say i want to change CSS of the line not phone. Thanks
