05-24-2014
03:07 AM
- last edited on
03-25-2019
08:29 PM
by
ciscomoderator
I just need to talk this logic out and see if it is sound. I am mid-rebuild on my lab and need to solve a problem...thanks in advance!
Desired Behavior:
They would like the gateway to only be able to dial the Receptionist. And then for the receptionist to be able to transfer calls from the gateway, as needed, to the Users. The users need to be able to dial out through the gateway and reach the receptionist.
I just want to verify that the transferred calls by the receptionist will still connect since the Users are in a partition that is not accessible by the Gateway's CSS. I know this is basic stuff but for some reason I am just drawing a blank right now! Frustrating....
I know this is convoluted but they want to make sure there is an extra level of separation from the gateway to the users to prevent some legacy DID behavior (LONG STORY).
Again..thanks!
Solved! Go to Solution.
05-25-2014 06:19 PM
Only the phone doing the transfer need to have access to the target DN.
05-25-2014 06:19 PM
05-25-2014 10:05 PM
Thanks for the response! That is what I thought but just wanted to verify.
