04-09-2019 11:52 PM - edited 04-09-2019 11:53 PM
We are using CUCM 10.5 version where i am unable to find the CDR reports for date which was 4 month back....
1. Are the CDR reports over write after some time
2. Is there any setting for CDR reports configuration for any particular time stamp
3. Is there any setting for CDR reports configuration for any disk space allocation
04-10-2019 12:29 AM
Hello Vijay,
The maximut time that the CUCM can hold data is 180 days. Below you will find a really useful post on Community:
George
04-10-2019 01:30 AM
04-10-2019 10:31 PM
04-10-2019 07:26 AM
The CDR tools built into Call Manager will allow you to pull a number of reports, but as others have pointed out, they do not store data for an indefinite time. If you are looking for a tool that will store years worth of call records, look for something like VoIP Detective (there is a limited, free version available).
04-10-2019 07:59 AM
The "reports" are not overwritten, the data from the CAR DB is overwritten if you go past the disk space that was allocated for it. So, even if you changed the max age parameter to 180, but you're generating a lot of calls in your system, the data you actually have in the DB will be for a shorter period of time.
04-10-2019 10:26 PM - edited 04-10-2019 10:27 PM
