03-25-2013 08:40 AM - edited 03-16-2019 04:26 PM
Hello guys!
In a scenario of a BE6000 consisting of a single CUCM 8.6.2.20000, single CUCxN 8.6.2.20000 and single CUP 8.6.2, which is the correct order for upgrading the servers?
From the documentation, the CUP must be upgraded after the CUCM is already on version 9. In fact, i tried and it gave me a version error. Lesson learned. But in terms of CUCxN and CUCM, which is the correct upgrade?
Thanks in advanced!
Solved! Go to Solution.
03-25-2013 10:26 AM
No difference, either you upgrade CUCM or CUC, it's the same, they're compatible.
But in regards to CUCM and IM&P, yes, when going to version 9.X and going forward, CUCM first, then IM&P.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
03-25-2013 09:34 AM
Hi Santos,
Please share the exact 8.6.2.x version of CUP and the exact error message/snapshot which u get while trying to upgrade CUP from 8.6.2 to 9.1.1a.
There are two type of upgrades : Standard and Refresh Upgrade.Let me check how I can help u.
regds,
aman
03-25-2013 09:38 AM
Hello Aman and thanks for your reply. The CUP version is 8.6.4.10000-28 and is a Standard Upgrade as per the documentation.
Thanks again for your reply.
03-25-2013 09:42 AM
Hi Santos,
You are correct as it is Standard upgrade.
Please share the error message and also please the patch name which u are using to upgrade.
regds,
aman.
03-25-2013 09:44 AM
Dont have the error output, but it was a version mismatch error. the new upgrade file is UCSInstall_CUP_9.1.1.10000-8.sgn.
03-25-2013 10:04 AM
Hi Santos,
Just a guess: Are u using PAWS [Platform Administrative Web Services Interface Management (PAWS] ?
regds,
aman
03-25-2013 10:17 AM
Performing upgrade through OS Administration Web GUI.
03-25-2013 10:26 AM
java
03-25-2013 10:32 AM
Great. Thanks Jaime.
