10-23-2012 07:13 PM - edited 03-16-2019 01:51 PM
I have two sites with 200 employee`s each one. I have two CUCM and I`m planning to install each server in a site.
Where I can install the CUCM Pub? There's any criteria? Any best practices to install CUCM Pub?
Both sites has a high MPLS speed and a good datacenter infrastructure.
10-23-2012 07:24 PM
You can follow the SRND guidelines for a Cluster over the WAN deployment:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/9x/models.html#wp1043996
Hope to help, remember to rate the post if it does.
Adrian.
10-24-2012 12:10 AM
The best place to put the pub is the one that is closest/easiest to get to !
GTG
10-24-2012 06:39 AM
The big restriction here is the physical distance, the SUB cannot be more than 20msec away from the PUB a total of 40msec roundtrip
10-24-2012 06:46 AM
Robert,
The round-trip latency is actually 80 ms as of I belive CUCM 6.X, assuming the bandwidth is met. You will need 1.5Mbps for ICCS traffic and 1.5Mbps for database replication for each Sub, so assume you have 2 subs remote from the pub, you would need 1.5+1.5*2=4.5 Mbps of dedicated bandwidth.
To answer the original question I would recommend placing the server at the most reliable data center. You may also consider other apps if you are planning on deploying them in non-redundant fashion, i.e. unity connection, UCCX, CUEAC, etc as if you won't split those across WAN you would want to keep them close to the Pub as well (not necessary but recommended).
HTH,
Chris
