Showing results forĀ
Search instead forĀ
Did you mean:Ā
CUCM DMA 5.1.3 to 8.X
wilsonsant
Level 6
Level 6
Hi Guys,
My Customer have one CallManager version 5.1.3 and would like change to version  8.X. My Question is: With DMA is it possible to do directly migration or I have intermediaty migration? Is there any docummentation about this?
Wilson
Rob Huffman
Hi Wilson,
DMA won't come into play for this upgrade as it's only used for windows CUCM versions
to Linux appliance CUCM version migrations. In you case you will need to move via an intermediate step before you can reach any CUCM 8.x version. Stay away from 8.0 as it has proven to be
quite buggy;
You will need to look at the tables in the attached guide to determine what the exact path will be
Table 4     Export Restricted Supported Cisco Unified Communications Manager Upgrades for Release 8.x
8.6(2)
8.6(1a)
8.5(1)SU2
8.5(1)SU1
8.5(1)
System Version
8.6.2.10000-30
8.6.1.20000-1
8.5.1.12900-7
8.5.1.11900-21
8.5.1.10000-26
Release Date
September 15 2011
June 23 2011
June 29 2011
Feb 9 2011
Nov 15 2010
Standard Support
Direct upgrade:
8.6(1a), 8.6(1), 8.5(1), 8.5(1)SU2, 8.5(1)SU1, 8.0(3a)SU2, 8.0(3a)SU1, 8.0(3a), 8.0(3), 8.0(2c)SU1, 8.0(2c), 8.0(2b), 8.0(2a), 8.0(2), 8.0(1), 7.1(5b)SU4(restricted), 7.1(5b)SU3(restricted), 7.1(5b)SU2(restricted), 7.1(5b)(restricted), 7.1(5a)(restricted), 7.1(5)SU1a(restricted), 7.1(5)SU1(restricted), 7.1(5)(restricted), 7.1(3b)SU2, 7.1(3b)SU1, 7.1(3b), 7.1(3a)SU1a, 7.1(3a)SU1, 7.1(3a), 7.1(3), 6.1(5)SU3, 6.1(5)SU2, 6.1(5)SU1, 6.1(5), 6.1(4a)SU2, 6.1(4a), 6.1(4)SU1, 6.1(4)
Direct upgrade:
8.6(1), 8.5(1), 8.5(1)SU2, 8.5(1)SU1, 8.0(3aSU2, 8.0(3a)SU1, 8.0(3a), 8.0(3), 8.0(2c)SU1, 8.0(2c), 8.0(2b), 8.0(2a), 8.0(2), 8.0(1), 7.1(5b)SU4(restricted), 7.1(5b)SU3(restricted), 7.1(5b)SU2(restricted), 7.1(5b)(restricted), 7.1(5a)(restricted), 7.1(5)SU1a(restricted), 7.1(5)SU1(restricted), 7.1(5)(restricted), 7.1(3b)SU2, 7.1(3b)SU1, 7.1(3b), 7.1(3a)SU1a, 7.1(3a)SU1, 7.1(3a), 7.1(3), 6.1(5)SU3, 6.1(5)SU2, 6.1(5)SU1, 6.1(5), 6.1(4a)SU2, 6.1(4a), 6.1(4)SU1, 6.1(4)
Direct upgrade:
8.5(1)SU1, 8.5(1), 8.0(3a)SU2, 8.0(3a)SU1, 8.0(3a), 8.0(3), 8.0(2c)SU1, 8.0(2c), 8.0(2b), 8.0(2a), 8.0(2), 8.0(1), 7.1(5b)SU4(restricted), 7.1(5b)SU3(restricted), 7.1(5b)SU2(restricted), 7.1(5b)(restricted), 7.1(5a)(restricted), 7.1(5)SU1a(restricted), 7.1(5)SU1(restricted), 7.1(5)(restricted), 7.1(3b)SU2, 7.1(3b)SU1, 7.1(3b), 7.1(3a)SU1a, 7.1(3a)SU1, 7.1(3a), 7.1(3), 6.1(5)SU3, 6.1(5)SU2, 6.1(5)SU1, 6.1(5), 6.1(4a)SU2, 6.1(4a), 6.1(4)SU1, 6.1(4)
Direct upgrade:
8.5(1), 8.0(3a)SU2, 8.0(3a)SU1, 8.0(3a), 8.0(3), 8.0(2c)SU1, 8.0(2c), 8.0(2b), 8.0(2a), 8.0(2), 8.0(1), 7.1(5b)SU3(restricted), 7.1(5b)SU2(restricted), 7.1(5b)(restricted), 7.1(5a)(restricted), 7.1(5)SU1a(restricted), 7.1(5)SU1(restricted), 7.1(5)(restricted), 7.1(3b)SU2, 7.1(3b)SU1, 7.1(3b), 7.1(3a)SU1a, 7.1(3a)SU1, 7.1(3a), 7.1(3), 6.1(5)SU3, 6.1(5)SU2, 6.1(5)SU1, 6.1(5), 6.1(4a)SU2, 6.1(4a), 6.1(4)SU1, 6.1(4)
Direct upgrade:
Direct upgrade using DMA:
none
Note Refer to the Notes about Engineering Specials (ESs), Service Updates (SUs), and Windows Service Release (SR) Upgrades concerning upgrades from ESs.
Your first step may have to be to CUCM 6.1(4) as shown below;
6.1(4a)SU2
6.1(4a)
6.1(4)SU1
6.1(4)
System Version
6.1.4.2190-3
6.1.4.2000-2
6.1.4.1190-3
6.1.4.1000-10
Release Date
Oct 22 2009
Sep 18 2009
Aug 25 2009
Jun 17 2009
Standard Support
Direct upgrade:
6.1(4a), 6.1(4)SU1, 6.1(4), 6.1(3b)SU1, 6.1(3b), 6.1(3a), 6.1(3), 6.1(2)SU1a, 6.1(2)SU1, 6.1(2)
Direct upgrade:
6.1(4)SU1, 6.1(4), 6.1(3b)SU1, 6.1(3b), 6.1(3a), 6.1(3), 6.1(2)SU1a, 6.1(2)SU1, 6.1(2), 5.1(3g), 5.1(3f), 5.1(3e), 5.1(3d), 5.1(3c), 5.1(3b), 5.1(3a), 5.1(3)
Direct upgrade:
Direct upgrade:
none
4.3(2), 4.2(3), 4.1(3)
none
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html#wp302770
Cheers!
Rob
