ā10-04-2011 12:36 PM - edited ā03-16-2019 07:19 AM
Hi Guys,
My Customer have one CallManager version 5.1.3 and would like change to version 8.X. My Question is: With DMA is it possible to do directly migration or I have intermediaty migration? Is there any docummentation about this?
Wilson
ā10-04-2011 12:52 PM
Hi Wilson,
DMA won't come into play for this upgrade as it's only used for windows CUCM versions
to Linux appliance CUCM version migrations. In you case you will need to move via an intermediate step before you can reach any CUCM 8.x version. Stay away from 8.0 as it has proven to be
quite buggy;
You will need to look at the tables in the attached guide to determine what the exact path will be
Cisco Unified Communications Manager | 8.6(2) | 8.6(1a) | 8.5(1)SU2 | 8.5(1)SU1 | 8.5(1) |
System Version | 8.6.2.10000-30 | 8.6.1.20000-1 | 8.5.1.12900-7 | 8.5.1.11900-21 | 8.5.1.10000-26 |
Release Date | September 15 2011 | June 23 2011 | June 29 2011 | Feb 9 2011 | Nov 15 2010 |
Standard Support | Direct upgrade: 8.6(1a), 8.6(1), 8.5(1), 8.5(1)SU2, 8.5(1)SU1, 8.0(3a)SU2, 8.0(3a)SU1, 8.0(3a), 8.0(3), 8.0(2c)SU1, 8.0(2c), 8.0(2b), 8.0(2a), 8.0(2), 8.0(1), 7.1(5b)SU4(restricted), 7.1(5b)SU3(restricted), 7.1(5b)SU2(restricted), 7.1(5b)(restricted), 7.1(5a)(restricted), 7.1(5)SU1a(restricted), 7.1(5)SU1(restricted), 7.1(5)(restricted), 7.1(3b)SU2, 7.1(3b)SU1, 7.1(3b), 7.1(3a)SU1a, 7.1(3a)SU1, 7.1(3a), 7.1(3), 6.1(5)SU3, 6.1(5)SU2, 6.1(5)SU1, 6.1(5), 6.1(4a)SU2, 6.1(4a), 6.1(4)SU1, 6.1(4) | Direct upgrade: 8.6(1), 8.5(1), 8.5(1)SU2, 8.5(1)SU1, 8.0(3aSU2, 8.0(3a)SU1, 8.0(3a), 8.0(3), 8.0(2c)SU1, 8.0(2c), 8.0(2b), 8.0(2a), 8.0(2), 8.0(1), 7.1(5b)SU4(restricted), 7.1(5b)SU3(restricted), 7.1(5b)SU2(restricted), 7.1(5b)(restricted), 7.1(5a)(restricted), 7.1(5)SU1a(restricted), 7.1(5)SU1(restricted), 7.1(5)(restricted), 7.1(3b)SU2, 7.1(3b)SU1, 7.1(3b), 7.1(3a)SU1a, 7.1(3a)SU1, 7.1(3a), 7.1(3), 6.1(5)SU3, 6.1(5)SU2, 6.1(5)SU1, 6.1(5), 6.1(4a)SU2, 6.1(4a), 6.1(4)SU1, 6.1(4) | Direct upgrade: 8.5(1)SU1, 8.5(1), 8.0(3a)SU2, 8.0(3a)SU1, 8.0(3a), 8.0(3), 8.0(2c)SU1, 8.0(2c), 8.0(2b), 8.0(2a), 8.0(2), 8.0(1), 7.1(5b)SU4(restricted), 7.1(5b)SU3(restricted), 7.1(5b)SU2(restricted), 7.1(5b)(restricted), 7.1(5a)(restricted), 7.1(5)SU1a(restricted), 7.1(5)SU1(restricted), 7.1(5)(restricted), 7.1(3b)SU2, 7.1(3b)SU1, 7.1(3b), 7.1(3a)SU1a, 7.1(3a)SU1, 7.1(3a), 7.1(3), 6.1(5)SU3, 6.1(5)SU2, 6.1(5)SU1, 6.1(5), 6.1(4a)SU2, 6.1(4a), 6.1(4)SU1, 6.1(4) | Direct upgrade: 8.5(1), 8.0(3a)SU2, 8.0(3a)SU1, 8.0(3a), 8.0(3), 8.0(2c)SU1, 8.0(2c), 8.0(2b), 8.0(2a), 8.0(2), 8.0(1), 7.1(5b)SU3(restricted), 7.1(5b)SU2(restricted), 7.1(5b)(restricted), 7.1(5a)(restricted), 7.1(5)SU1a(restricted), 7.1(5)SU1(restricted), 7.1(5)(restricted), 7.1(3b)SU2, 7.1(3b)SU1, 7.1(3b), 7.1(3a)SU1a, 7.1(3a)SU1, 7.1(3a), 7.1(3), 6.1(5)SU3, 6.1(5)SU2, 6.1(5)SU1, 6.1(5), 6.1(4a)SU2, 6.1(4a), 6.1(4)SU1, 6.1(4) | Direct upgrade: 8.0(3a)SU2, 8.0(3a)SU1, 8.0(3a), 8.0(3), 8.0(2c)SU1, 8.0(2c), 8.0(2b), 8.0(2a), 8.0(2), 8.0(1), |
Direct upgrade using DMA: none | |||||
Note Refer to the Notes about Engineering Specials (ESs), Service Updates (SUs), and Windows Service Release (SR) Upgrades concerning upgrades from ESs. |
Your first step may have to be to CUCM 6.1(4) as shown below;
Cisco Unified Communications Manager | 6.1(4a)SU2 | 6.1(4a) | 6.1(4)SU1 | 6.1(4) |
System Version | 6.1.4.2190-3 | 6.1.4.2000-2 | 6.1.4.1190-3 | 6.1.4.1000-10 |
Release Date | Oct 22 2009 | Sep 18 2009 | Aug 25 2009 | Jun 17 2009 |
Standard Support | Direct upgrade: 6.1(4a), 6.1(4)SU1, 6.1(4), 6.1(3b)SU1, 6.1(3b), 6.1(3a), 6.1(3), 6.1(2)SU1a, 6.1(2)SU1, 6.1(2) | Direct upgrade: 6.1(4)SU1, 6.1(4), 6.1(3b)SU1, 6.1(3b), 6.1(3a), 6.1(3), 6.1(2)SU1a, 6.1(2)SU1, 6.1(2), 5.1(3g), 5.1(3f), 5.1(3e), 5.1(3d), 5.1(3c), 5.1(3b), 5.1(3a), 5.1(3) | Direct upgrade: 6.1(4), 6.1(3b)SU1, 6.1(3b), 6.1(3a), 6.1(3), 6.1(2)SU1a, 6.1(2)SU1, 6.1(2) | Direct upgrade: 6.1(3b)SU1, 6.1(3b), 6.1(3a), 6.1(3), 6.1(2)SU1a, 6.1(2)SU1, 6.1(2), 5.1(3g), 5.1(3f), 5.1(3e), 5.1(3d), 5.1(3c), 5.1(3b), 5.1(3a), 5.1(3) |
Direct upgrade using DMA: none | Direct upgrade using DMA: 4.3(2), 4.2(3), 4.1(3) | Direct upgrade using DMA: none | Direct upgrade using DMA: 4.3(2), 4.2(3), 4.1(3) | |
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html#wp302770
Cheers!
Rob
