10-11-2012 08:01 AM - edited 03-16-2019 01:38 PM
Does anyone know if it is possible for someone to "pull back" a call that they transfered? For example, if this person transfers a call by acciident, can they pull that call back to their extension?
10-11-2012 08:12 AM
Hi there,
This type of functionality is only available if you train users to use
a Consult Transfer rather than Blind Transfer. If you do a Consult
Transfer by;
Active call > Transfer Softkey > Dial # > wait for called party to answer > Press Transfer
Softkey a second time. The call can be pulled back by Pressing the Line Button
before the Transfer Softkey is pressed the second time
If they do a Blind Transfer by;
Active call > Transfer Softkey > Dial # > Press Transfer
Softkey a second time (or hangup if enabled). The call cannot be pulled back
and it's gone for good
Cheers!
Rob
"May your heart always be joyful
May your song always be sung" - Bob Dylan
10-11-2012 08:17 AM
Thanks Rob. This end user had a dial pattern in their previous phone system (NEC) which allowed them to "pull a call back".
10-11-2012 08:32 AM
Hi there,
Do you know the exact NEC PBX model they were using?? I can't seem to
find that feature in any of the NEC docs that I can find
Cheers!
Rob
10-11-2012 08:46 AM
it was actually a samsung system....and i have no clue how any of the NEC or Samsung PBXs work. Thats why we went with Cisco
10-11-2012 08:52 AM
Was this possibly a Call Park feature that may just not sound as clear based on the description? Just a thought...maybe this is describing a scenario where a call was parked (not necessarily transferred) and then there was a pattern to pick that call back up from another phone?
Hailey
10-11-2012 08:50 AM
Hey Rob good approach (+5)
Not sure if that is the same, but I had a customer using NEC and other PBX plataform that they were able to retrieve a Call using the Call-pickup codes, for NEC is possible to pick-up a call that is ringing at another extension by using a Call Pickup codes.
** + Extension
This workaround is in use for several customer that i know of.
On this Guide found " Googlein " about that. Look into " Transferring Calls" section
10-11-2012 09:14 AM
Hi Hailey & Bruno,
Thanks for weighing in here +5 to both of you for trying
to investigate the feature parity here. I'm always curious to
find out what customers have found useful on other systems
to see what we can do to try a match up a solution for them on CUCM.
It's not always possible, but for the most part, (if we get creative) a
reasonable solution can be found. It's a real "ART" to try and decipher
what the customer is asking for in many cases, but it is incumbent
on a good engineer to try and "read between the lines" & come up with
something that works for both
So.......we keep on trying
Cheers!
Huff
