CUCM Integration with LDAP from Different Companies
asherif82
We have a Multi tenant scenario is that  10 different companies located in same location and each one is acting as a totally seperate domain (such as cisco.com and microsoft.com) and all need to be integrated with UCM Cluster located in that location, I have some questions regarding that design:
1-Is it applicable to integrate one UCM cluster with seperate different domain companies not located under the same forest (each one is totally seperate that the other one?
2-If yes ,how many LDAP connection can UCM handle (Up to How many domains can be added in UCM)?
3-For corporate directory seach ,How the user can only search his/her related colleague within the same domain and not be seen by other domains (each domain is sperated from the other)?.
Please advise.
Amr Sherif
2 Accepted Solutions
Chris Deren
CUCM can support 5 directory integrations, but only one authentication. The workaround is implementation of MSFT ADAM/LDS.
Chris
Jaime Valencia
And youll need to build custom directory scripts to only have users from each domain within it.
java
if this helps, please rate
Chris Deren
Chris
Jaime Valencia
java
