CuCm license
Isfds
hello team,
I want to use the cisco cucm  to manage 40 phones and 2 lines.
Will I need a license for this?
Please can help me on this.
Jaime Valencia
Yes you will need licenses, engage a local Cisco partner WITH voice specializations for assistance, or a Cisco distributor as an alternative. Discuss with them your needs and requirements, and they will provide you with options that suit your needs.
java
if this helps, please rate
Martin L
In the past you had 6 months to enter license; in other words, CUCM works for a period of time without any licenses. then, you must enter license  or re-install it completely.
Regards, ML
**Please Rate All Helpful Responses **
Jaime Valencia
java
