CUCM log storage space
Karthika
Hi All,
I would like to get some idea regarding call manager log storage :
We have CUCM version 11.5 and would like to know how many days of logs the call manager can store.
I completely understand it is based on the "Trace Output settings" and based on the call volumes.
But i just need a approximate calculation on "how many days of logs we would be able to see or in turn what would be the last time stamp we can see from the logs".
IS it possible if anybody can help me on the same?
From Trace settings:
Maximum No. of files :  750
Maximum File settings : 10 MB
Thanks In Advance!
Karthika
Jaime Valencia
As you just said, it depends on call volume, no one size fits all answer to that question. When I was in TAC, some systems would hold just about a day due to the call volume. Look at your system to tell how far it goes with your usual load and that will be your answer
java
if this helps, please rate
balaji.bandi
As per my experience.
we have done some analytics, since our CUCM as VM, We have configured storage as a decent start with 1 TB.
we are continuously monitoring the space every day and weekly and monthly basis, like we did for 3 months and come to conclusion of average disk space we need for the setup.
1. again we need to consider organisation standards, how long we need to keep logs for governance.
2. can we offload any other place like back up.
3. We need to also do life cycle process if any of the call volume increases.
BB
ardugar
I am answering this assuming you are referring to "Cisco call manager traces".
It will very much depend upon the call volume but you can run the below command on each node in your cluster to check the number of trace files and the date/time they were generated. The latest file generated will be at bottom and the oldest file at the top. This will give you general idea how many files your system can store before being overwritten.
file list activelog /cm/trace/ccm/sdl/ dat det
