CUCM name
benmather
hi,
what is the difference in how the name field is used in CUCM?  for example, it seems that it is good practice to add a server by its IP address under System - Server.  if i go to System - Cisco Unified CM - and select a server, there is a field for "Cisco Unified Communications Manager Name".  what is this field used for, versus the name under System - Server?  should I also change this to the IP address?
In a related query, if I am on the command line and I do a "utils dbreplication runtimestate", where does CUCM draw the "SERVER-NAME" from, and can this be changed?
thank you.
Nishant Savalia
Level 4
Level 4
Hi Ben,
The "Cisco Unified Communications Manager Name" field under system is just for your reference. You can specify name for your ease and same will get reflect and help you to select servers while defining CUCM Group.
What ever name you define during your installation of CUCM server, same will be updated under System - server.
Nishant Savalia
Regards, Nishant Savalia
Nishant, thank you.  This makes sense.
Chris Deren
Latest SRND recommends using FQDN as oppose to IP address, the main reason is MRA (Collab Edge) requires FQDN in order to work. If using FQDN you need to ensure your phones can resolve it in DNS.
Chris
thanks, it is possible we may use the collab edge product in the future so i'll keep this in mind.
