03-07-2013 12:38 AM - edited 03-16-2019 04:07 PM
Dear All
i am planning to upgrade our Call Manager from Version
8.6.2.21900-5 to CUCM 9.X below is my hardware detail. i would like to know it is possible to upgrade by using same hardware as below
admin:show version active
Active Master Version: 8.6.2.21900-5
Active Version Installed Software Options:
cmterm-bfcp-e.8-6-2.cop
ciscocm.refresh_upgrade_v1.1.cop
cmterm-android-12.cop
admin:show hardware
HW Platform : 7835H2
Processors : 1
Type : Family: Xeon
CPU Speed : 2333
Memory : 6144 MBytes
Object ID : 1.3.6.1.4.1.9.1.584
OS Version : UCOS 5.0.0.0-2
Serial Number :
RAID Version :
RAID Firmware Version: 7.22
RAID BIOS Version: N/A
BIOS Information :
10/25/2010
RAID Details :
Smart Array P400 in Slot 1
Bus Interface: PCI
Slot: 1
Serial Number: PAFGK0P9VWY1Z5
Cache Serial Number: PA82C0J9VWY19R
RAID 6 (ADG) Status: Enabled
RAID 6 (ADG) Enabler Status: Enabled
Controller Status: OK
Chassis Slot:
Hardware Revision: Rev E
Rebuild Priority: Medium
Expand Priority: Medium
Surface Scan Delay: 15 sec
Cache Board Present: True
Cache Status: OK
Accelerator Ratio: 50% Read / 50% Write
Total Cache Size: 256 MB
Battery Pack Count: 1
Battery Status: OK
SATA NCQ Supported: True
Array: A
Interface Type: SAS
Unused Space: 0 MB
Status: OK
Logical Drive: 1
Fault Tolerance: RAID 1+0
Heads: 255
Sectors Per Track: 32
Cylinders: 35132
Stripe Size: 64 KB
Status: OK
Array Accelerator: Enabled
Unique Identifier: 600508B100105039565759315A350001
Disk Name: /dev/cciss/c0d0
Mount Points: /partB 24.5 GB, / 24.5 GB, /grub 258 MB, /common 85.4 GB
physicaldrive 1:1
Port: 2I
Box: 1
Bay: 1
Status: OK
Drive Type: Data Drive
Interface Type: SAS
Rotational Speed: 10000
Firmware Revision: HPD6
Serial Number: BS05P8B0NNDP0848
Model: HP DG146BABCF
physicaldrive 1:2
Port: 2I
Box: 1
Bay: 2
Status: OK
Interface Type: SAS
Serial Number: BS05P8B0NNDM0848
Solved! Go to Solution.
03-07-2013 01:19 AM
MCS-7835-H2 is only supported for bridge upgrade...
Here is the hardware requirements..
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
03-07-2013 01:19 AM
