CUCM one of the branch no incoming or outgoing call
amjed.ali
Jaime Valencia
Start by debugging your GW to confirm outbound calls and inbound calls are reaching it, then you can take it from there depending on what the debugs show and adjust as required.
FYI, you want to sanitize what you post here, you just exposed your users and passwords.
java
if this helps, please rate
Jaime Valencia
java
