10-12-2012 06:55 AM - edited 03-16-2019 01:39 PM
Has anyone ever seen where after the user logs into their Personal Directory, they have to login each time, and if so, what did you do to fix it? I've always had it save your login unless the phone was reset.
10-12-2012 07:01 AM
Couple similar threads:
https://supportforums.cisco.com/message/1120123#1120123
https://supportforums.cisco.com/message/1103761#1103761
Chris
10-15-2012 07:22 AM
Thanks, but neither of those solved my problem.
10-25-2012 02:58 AM
Hi Bryan,
Can you please try the following workaround
1.Setup EMCC for the user
2.Setup PD as service for the user
3.Have the user login via EMCC on any Phone that they go to
4.User can access PD via the services button w/o logging in
This is documented in cisco BUG ID CSCth75231
Thanks and Regards,
Geevarghese
