06-01-2018 01:05 PM - edited 03-17-2019 12:56 PM
Hi, I will need to patch esxi on the publisher, subs are patched already. Do i need to restart subs after PUB patching complete and I power it up ?
As I understand when I shutdown PUB I dont need to touch subs, correct ?
thank you
Solved! Go to Solution.
06-01-2018 01:09 PM
Upgrading/patching ESXi is completely independent of CUCM, if you just shutdown the PUB to do this, then just bring it back up.
06-01-2018 01:21 PM - edited 06-01-2018 01:23 PM
No. You can shutdown Pub. Upgrade the ESXi version. Once competed turn back the Pub ON.
However it’s always recommended to check the dB replication/service status and make sure no errors after any node restart.
Also take a backup prior to reboot
Hope this helps
Cheers
Rath!
***Please rate helpful posts***
06-01-2018 01:09 PM
06-01-2018 01:12 PM
so I dont need to touch SUBs, to start replication or other database sync, correct ?
Hope this helps
Cheers
Rath!
