11-20-2015 06:34 PM - edited 03-17-2019 04:59 AM
Hi All,
I need some opinions on the failover roll of pub & sub, and how best to design failover based on their setup.
We have 2 units of BE6k:-
Total of 900 Ip phones:-
Each site has a voice gateway for E1/T1 telco link, where telco will forward calls in parallel
We will be doing cluster over WAN, for the CUCM, CUCIMP, CUC, UCCX.
Since we only have 2 boxes,we are looking installing Publisher at HQ and Subscriber at RemoteSiteA
The question is; which should be the ideal unit to take on the role for call processing & device registration?
or should both Pub & Sub do the load sharing?
or should HQ ip phones registers to Pub and Remotesite ipphones registers to Sub~?
In terms of maintenance wise, would load sharing pub+sub = hassle+tedious
What is the best practise in my scenario?
Appreciate any insight
Solved! Go to Solution.
11-21-2015 07:05 AM
11-22-2015 05:23 PM
No as the CUCM nodes are not licensed in releases of CUCM and you can have up to 8 call processing servers in a cluster.
11-20-2015 07:08 PM
In ideal scenario you don't have Publisher doing the call processing and phones are registered with subscribers for call processing. However, in your case since there is only one server at each site you can register the phones to local servers at each location and have the server of the other location as a backup for TFTP in the option 150 and call processing in the callmanager group. Since your setup is already close to the limit of max devices in BE6K you don't have to worry about any scalability or performance issues once this setup starts functioning normally in this way.
Manish
- Do rate helpful posts -
11-22-2015 05:24 PM
Thanks Manish for the info.
If i understands your info correctly, you are sugguesting for PUB to do the call processing + TFTP for HQ, and SUB to do the call processing+TFTP for RemoteSite. That both backups each other as secondary?
11-22-2015 05:31 PM
That is correct, same as pointed by Chris as well [+5]
Manish
11-22-2015 05:49 PM
Awesome! Thanks
On a side note, is it possible for the servers to swap role, eg Publisher to Sub, and Sub to Pub when its already fully installed with phones registered?
Reason being, at the moment HQ site is not physically ready, ie server room.
But RemoteSite is ready and that i can start server installation there. Which means ill need to install Pub at remoteSite for the start, then work on HQ installation when the site is ready.
Appreciate your advise
11-22-2015 05:52 PM
Unfortunately there is no way to do that, your best bet might be to re-host the pub and move the virtual machine at that point.
01-13-2016 09:39 PM
hi Manish,
So ideally i would turn on all the services available to my publisher, and do the same at on my subscriber correct?
We're looking at services like CallManager, CTIManager, TFTP, DirSync, AXL, TAPS turned on, on both pub and sub?
01-13-2016 09:43 PM
In your scenario with two servers in the cluster and one server at each location this would be the correct option.
Manish
01-14-2016 06:12 AM
Do not turn on all services, only start services you need so that you do not waste CPU cycles on things you do not need.
11-21-2015 07:05 AM
11-22-2015 05:16 PM
hi Chris,
Thanks for your valuable input. Its a great idea to have a 2nd sub in HQ. However we have bought only 2 sets of CUCM licenses/cuwl. Does that limit us in having a 2nd sub in HQ?
11-22-2015 05:23 PM
11-22-2015 06:47 PM
Do remember that you can add additional BE6000 servers in a cluster, however a deployment of BE 6000 solution on UCS C200 Rack-Mount Servers in a cluster exceeding 1,000 users and 1,200 configured devices is considered a regular Unified CM cluster, and as such it is bound by all pricing and licensing requirements and design guidance for regular Unified CM clusters and UC on UCS deployments.
Manish
