CUCM reports
erinedison
Can i please be directed of how to get reports from CUCM 10.5.
i am asked to provide the report of an external number,
who called this number xxxxxx and from which extension ?
please advise,
Thank You,
Erin
Suresh Hudda
For this cdr flag service parameter should be set to true..if it is not set then you can't get this detail. If it is already true then browse HTTP://<cucm pub ip>/car
Hope services related to cdr are up in cucm.
Suresh
Manish Gogna
Hi Erin,
In addition to the nice info provided by Suresh, please use the following doc to enable CDR reporting on your cucm
https://supportforums.cisco.com/document/53056/understanding-cdr-call-detail-records
If it was not already enabled then you will not be able to get the reports , CDR's will be logged only when cucm is configured as per the above doc.
Manish
erinedison
Hi All,
managed to get the answer(just that it may help some)
ssh >
admin: run sql car select callingpartynumber,originalcalledpartynumber,datetimeorigination from tbl_billing_data
get the report from putty logs and manipulate the output by excel(delimited).
Hi Erin,
You can use 3rd party Call Accounting Solutions which will provide more information and granular understanding of the CDR and generate report based on it.
Prasana
Regards, Prasana Kumar.P +919841027006
