05-16-2016 04:53 PM - edited 03-17-2019 06:56 AM
Can i please be directed of how to get reports from CUCM 10.5.
i am asked to provide the report of an external number,
who called this number xxxxxx and from which extension ?
please advise,
Thank You,
Erin
05-16-2016 07:40 PM
For this cdr flag service parameter should be set to true..if it is not set then you can't get this detail. If it is already true then browse HTTP://<cucm pub ip>/car
Hope services related to cdr are up in cucm.
Suresh
05-16-2016 08:44 PM
Hi Erin,
In addition to the nice info provided by Suresh, please use the following doc to enable CDR reporting on your cucm
https://supportforums.cisco.com/document/53056/understanding-cdr-call-detail-records
If it was not already enabled then you will not be able to get the reports , CDR's will be logged only when cucm is configured as per the above doc.
Manish
05-16-2016 09:36 PM
Hi All,
managed to get the answer(just that it may help some)
ssh >
admin: run sql car select callingpartynumber,originalcalledpartynumber,datetimeorigination from tbl_billing_data
get the report from putty logs and manipulate the output by excel(delimited).
05-20-2016 03:46 AM
