CUCM _root high Active sessions causes server crash
Mortaza Rohani
We are periodically facing CUCM high CPU caused by tomcat1 process and it leads to server crash and only resolved by hard reset of CUCM.
here is th network diagnostic result:
The following web applications have an unusually large number of active sessions: _root. Please collect all of the Tomcat logs for root cause analysis: file get activelog tomcat/logs/*
and this is show perf query class "Cisco Tomcat Web Application" result:
==>query class :
 - Perf class (Cisco Tomcat Web Application) has instances and values:
 _root -> Errors = 340
 _root -> Requests = 524
 _root -> SessionsActive = 176
I've found some java errors in catalina log file which is attached.
where can I find the causing session?
0 Replies 0
