IP 7821 phones display overlaps missed call logs icon with voicemail mwi icon . Is there a way to separate or disable this icon so that only Call logs can be seen ?
We upgraded one of our CUCM/IM&P clusters from 14SU2 to 15SU2 using data import/export and now we can't change the presence status to Away, DND or any custom status. It just continues to stay at Available. Also, IM&P shows the number of Assigned Us...
I have one Cisco 7811 and one Cisco 7821, both connected to a FusionPBX (FreeSWITCH) system.I tested 3-way conferencing, and it works fine. However, when I try to invite a fourth participant, only the Join softkey appears. When I press it, the call d...
Beside the obvious name what is the real difference of NANP:PreDot versus PreDot on CUCM? I was making a couple of test and they do the same for patterns like: 9.[2-9]XXXXXX 9.011!# 555.42XX 777800.[2-9]XXXXXX So I don't really understand the dif...
Guys, I need to query and check the 'Line Association' checkbox in remote Destination automatically based on some business conditions. Since we already use the AXL API to perform this type of action, we decided to follow this approach. However, I can...
I get complaints from users on the 7821 that when there is a voice message the voice message (VM) symbol overwrites the missed called symbol. The solid red light on the handset is also turned on when there is a voice message. So, this is redundant ...
Is it possible to trigger a route pattern based on the calling Party number?For example, MYApp with Caller ID "544449" having a SIP trunk with Cisco calls a Cisco extension 3000 (Not DN).My requirement is to transform this caller ID 544449 to 44449 b...
I am using 10.1.7.20 Unified Communications Self Portal to forward calls to my AT&T iPhone cell phone, but the calls are not being connected. Is there anything I can do on my end to enable this connection?
Hi all, in our MRA deployment we have a user requesting to use the IP phone personal directory as it is currently not working (the error shown is file not found). It seems that this feature is in a grey area as not listed as supported feature in the ...
Hi All , I am not able to forward the incoming and outgoing call from my Cube to CUCM . I am sharing the configuration and Pcap for the same .. Please suggest the solution... I am attaching all the detail , my SIP trunk is up between CUBE to ISP . ...
Good MorningWe have a pair of ISR4331 on version 17.12.4a which are used to route calls from the PSTN to and from CUCM and MS Teams calling. SIP connections to the PSTN are on dedicated trunks to the Telco. SIP connection to MST go via our Internet ...
CUCM VERSION 8.5.1 GOAL: UPGRADE FIRMWARE FOR 8831 CONF PHONE. Hello, I've just uploaded successfully the cmterm-8831-sip.10-3-1-16.cop.sgn cop file. Now when I goto OS ADMIN GUI to upload the load I get "Name does not match any filter pattern". ...
Hi,Here is my setup:Call Manager Express: 12.0 on 2911 routerPhones: Cisco 8841/8851 with 12.8.1 firmwareI am trying to set the back light settings so it is active from 7am - 10 pm daily. I've done the following steps, but it is not working.Configure...
Hi im not good with voip i need help with configuring CORlistI have cme router with 4 FXO portsAnd sccp phonesI want only 4 phones to be able to call external numbersThe configuration i tried on 1 phone but didn't workDial-peer cor customname externa...
I recently purchased an old model of Cisco unified ip phone. Model CP - 6961. I powered it on using POE and i can also see the phone with the same ip range on my network scanner. Query is, like any other regular VoIP phone, should the Cisco 6961 phon...
Subject | Author | Posted |
07-09-2025 09:52 AM | ||
07-08-2025 12:50 PM | ||
07-02-2025 08:49 AM | ||
07-01-2025 09:51 PM | ||
06-30-2025 02:50 AM |
User | Count |
2 | |
2 | |
1 | |
1 | |
1 |
